Turtle Wax Hybrid Solutions Pro Graphene To The Max Wax vs Turtle Wax Hybrid Solutions Pro Graphene Flex Wax
(spray)
The Turtle Wax Hybrid Solutions Pro Graphene Flex Wax is the company’s most versatile spray, which delivers an unmatched tighter web of protection. Infused with graphene – the lightest, thinnest, strongest substance known to man – this car wax brings professional levels of durability, water repellence, gloss and slickness, with long lasting results.
Flex Wax can be applied as a protective coating after paint correction, a topper coating over wax, a regular maintenance product after washing, or a standalone protective coating. When properly cured, you’ll enjoy unrivalled resistance against chemicals, elements and UV rays even under the harshest of conditions, year-round.
Flex Wax is safe to use on all exterior vehicle surfaces. For best results when used as a coating, apply the car wax to a clean, prepped car and allow it to cure for 24 hours for protection that lasts up to 12 months.
Features & Benefits:
Patent-pending graphene-infused spray delivers a tighter web of protection against water spotting, environmental elements, chemical contaminates and harsh UV rays
Adds gloss and slickness, leaving a showroom shine and finish
Can be used on wet or dry paint, as a protective coating or as simple maintenance after washes
Can be used in direct sunlight and on all exterior surfaces including glass, headlights, trim and wheels
Use and Care:
For Dry Application:
1) Wash and dry your vehicle
2) Apply 1-2 sprays of Pro Flex Wax to a fresh, microfibre towel or directly onto the surface of your car to build up the foundation of your finish
3) Buff product into one panel at a time using your microfibre cloth to achieve a glossy, showroom finish
For Wet Application:
1) Wash your car. Rinse thoroughly
2) While the surface of your car is wet, apply Pro Flex Wax sparingly to any nonporous surface to refresh and protect your delicate clear coat
3) Towel dry for a fresh, sparkling shine
(wax)
Ideal for professional detailers, auto enthusiasts and weekend warriors alike, the Turtle Wax Hybrid Solutions Pro Graphene To The Max Wax is a high-quality and durable liquid car wax that will help to take your detailing routine to the next level.
Turtle Wax’s patent-pending graphene-infused formula delivers long-lasting depth of colour, gloss, slickness and UV protection. The car wax also contains super-hydrophobic polymers, which provides your car with months of protection against chemicals, water and stains.
The easy-on, easy-off formula can be applied by hand or by a machine polisher using a soft foam buffing pad with 3-4 dime-sized drops. Allow the product to dry to a haze on the surface before gently removing it with a clean, dry microfibre cloth. For the longest-lasting protection, allow the paint to cure for 24 hours after application.
Adds extreme gloss, slickness and depth of colour, leaving a professional showroom shine and finish
Patent-pending graphene-infused formula creates a tighter web of protection on your vehicle’s paintwork
Super-hydrophobic polymers glide on for maximum water beading, stain prevention and resistance to chemicals and harsh UV rays
Easy-on, easy-off liquid can be applied by hand or by machine
Use and Care:
1) Wash your vehicle and rinse thoroughly. Clay and polish if needed to remove embedded dirt, contaminants, scratches, & swirl marks. Use Hybrid Solutions Pro 1 & Done Compound Correct & Finish™ to remove paint imperfections before applying wax
2) Apply 3 dime sized drops to an applicator pad and spread evenly over a 2’ x 2’ section using an overlapping circular motion
3) Wait 2-3 minutes to allow product to dry and haze
4) Fold a fresh microfiber towel and gently wipe excess product from the car’s surface using light, back-and-forth motions
5) Continue working in 2’ x 2’ sections until you have covered the entire surface of your car
6) To remove streaks or remaining product use a damp microfiber towel and finish by wiping with a soft dry microfiber towel
Popełniłem dziś taki dziwny test 🙂
Jak wspomniałem w tym temacie:
Zachciało nam się usunąc woski House OF Wax z powodu tego, że auto trafiło przypadkiem na szczotkę ręczną i lakier po ostatniej polerce wyglądał jak sieczka.
Enigma AIo robi robotę ❤️
Mój drugi ulubiony produkt zaraz po HoW Cleaner 😄
Wspomniałem, że to dziwny test bo nie wiem czy ma sens. Auto "spolerowaliśmy" Enigma AIO a jak wiemy ten produkt ma dodatki kwarcu.
No a na to nałożyliśmy produkty grafenowe Turtla 😄 Także mix technologi - kanapka rodem z NASa. Kwarc + grafen rodzi się kapitan Sandwitch 😉
Ale jak sobie wpiszecie w google Sio2 + Graphen jest dużo ciekawych tematów także czort wie 😉
Dobra, nie wiem co to będzie i jak będzie ale na pewno będzie test tych produktów jako samodzielne zabezpieczenie wkrótce.
Tutaj chciałem już mieć auto gotowe przed lub nawet na zimę ale też sprawdzić z czym się je te grafeny. Niestety od 10 miesięcy mój blok ma termomodernizację i nie mam balkonu aby porobić sobie laboratoryjne testy balkonowe ;( ;( ;(
  • Aplikacja:
Trzeba mocno uwazać aby nie przedobrzyć z aplikacją obydwu produktów, raczej starać się oszczędnie. Bo (spray) zanim zwiąże i odparuje tworzył na tym lakierze mocne hazy i holosy a docieranie było małym koszmarem. Tutaj liczy się zasada mało, dobrze rozcierać, dać odparować z 5 minut i docierać.
Aplikacja i docieranie (wax'a) było ciut lepsze niż (spray'a). Oba produkty zostawiają mazy, które na tym czarnym uni trzeba było uważnie docierać.
Aplikacja na tym lakierze (wax) 4/6
Aplikacja na tym lakierze (spray) 4/6
Docieranie na tym lakierze (wax) 3+/6
Docieranie na tym lakierze (spray) 3/6
Śliskość (wax) i (spray) 3/6
  • Efekt końcowy:
Oba produkty są z tych przyciemniających. Tworzą fajną czerń z mocną głębią.
Efekt końcowy - moim subiektywnym zdaniem - na tym lakierze (wax) 5/6
Efekt końcowy - moim subiektywnym zdaniem - na tym lakierze (spray) 5/6
Sorki ale moje umiejętności robienia fotek lustrzanką są daremne 😉
Moim skromnym zdaniem uważam, że (wax) po lewej przyciemnia trochę mocniej niż (spray) po prawej.
To co zauważyłem, że bardzo szybko produkty zaczeły łapać wilgoć i po stronie (spray) była większa reakcja potna, koło godziny 18:00 przy temperaturze 14st.
Data Aplikacji: 02.X.2021 przy przebiegu: 295 150km
Zobaczymy jak to posiedzi, ile i z jakim efektem a na innym aucie zrobimy test samodzielny nie na Enigmie AIO jak tutaj 😉
Mam możliwość przytargania do Polski turtlasa grafenowego w paście. Jakby co daj znać I podpytam terminy.
Który to pls ?
Btw. Właśnie wpadł inny filmik:
Widzę, że o aplikacji i dotarciu ma to samo zdanie 😉
Który to pls ?
No właśnie oglądałem wczoraj wieczorem i śmiechłem mocno z porównywanych produktów.
Rozwiń 🙂
Mam pytanie, być może głupie. Jaka jest przewaga grafenu w porównaniu do polimerów? Na forum jest kilka testów produktów z grafenem, no i d..y nie urywa... Trwałość, łatwość aplikacji, wygląd, hydrofobowość czy tylko marketing uzasadniający napompowaną cenę? Nie chodzi mi o konkretną markę. W moim przypadku na lakier co miesiąc wrzucam TW Ice, a po każdym myciu Ech2o 1:15. Jest tanio i dobrze.
Grafen lepiej brzmi! Serio, to dla mnie nie ma sensu póki co. Może za kilka lat temat grafenu w powłokach rozwinie się trochę bardziej i będziemy mieli namacalne zalety, bo póki co to dla mnie marketing.
  • 4 tygodnie później...
Update
Pierwsze Mycie: 07.XI.2021 przy przebiegu 297 017km - czyli 36 dni co stanowi 1 miesiąc i 5 dni oraz 1867km dalej
Efekt prima sort - co tu dużo gadać 🙂 36 dni oraz 1867km dalej 🙂
Po stronie MAX delikatna tafeleczka przy zaciąganiu wodą pod cienieniem - smuga - ale spływa szybko 🙂
Na całym aucie produkty trzymają się rewelacyjnie - jak dla mnie na chwilę obecną ocena 5.5/6
Filmik 🙂:
https://youtu.be/5j35SLUW4-g
  • 5 miesięcy temu...
Pierwsze Mycie: 07.XI.2021 przy przebiegu 297 017km - czyli 36 dni co stanowi 1 miesiąc i 5 dni oraz 1867km dalej.
Drugie Mycie: Grudzień ? Bezdotyk ?
Trzecie Mycie: Luty ? Bezdotyk
Czwarte Mycie: Kwiecień ? Bezdotyk ?
Piąte Mycie: 07.V.2022 przy przebiegu 299 942 km - czyli 217 dni co stanowi 7 miesięcy i 5 dni oraz 4792km dalej.
Piąte mycie. Niestety drugie moje. Nie miałem kiedy robić serwisu. Szwagier 3 razy w ciągu 7 miesięcy był na myjni i wymył auto. Nie wiem czy szczotą, czy pianą 😉 Ale jest to 5 mycie w sumie i teraz "konkretniejszy" serwis 😉
Także zobaczycie te produkty po 217 dniach co stanowi 7 miesięcy i 5 dni oraz 4792km dalej oraz po 5 myciach 🙂
Przed:
Wyciągnąłem moja K5 w końcu. Zamierzam ją doinwestować czyli elastyczny dłuższy wąż i te wszystkie bajeranckie pistolety 😉
Po prewashu - będziemy myć Neoxalem 737 - dwa razy.
Mycie i efekty 😉
https://youtu.be/eU7dVcs3-Oo
Efekt wizualny po 4792km i 217 dniach oceniłbym: strona lewa WAX 2.5/6 i strona prawa FLEX 3/6.
Nie są to dla mnie efekty wizualne które urywają cztery litery ale definitywnie produkty jeszcze siedzą. Jak na dwa porządne mycia, 3 bezdotyki, 217 dni i 4792 generalnie moja finalna sumaryczna ocena to 4/6 ale z przewagą dla FLEX'a czyli produktu w spray'u po stronie prawej 😉
Robi robotę skubaniec a to spray więc przy aplikacji raz w miesiącu mamy ochronę non stop 🙂
  • 3 miesiące temu...
W dniu 2.10.2021 o 23:01, Domel napisał:
  • Aplikacja:
W piątek w nocy wróciłem z urlopu i od południa walczyłem już z autem 😉
Spolerowałem lakier Enigma AIO. Wyszło całkiem ładnie 🙂
24h później czyli w sobotę koło 17:00 nakładałem: Turtle Wax Hybrid Solutions Pro Graphene Flex Wax (spray)
Potwierdziło się wszystko co pisałem (za cytowałem) wyżej - trochę się umordowałem na tym lakierze z docieraniem bo moja ręka nie zna umiaru 😉
Aplikacja na tym lakierze (spray) 4/6 - generalnie spoko. Psik na mikrofibrę i jazda. Zostaje widoczna siatka jakby zaciek i staramy się go dotrzeć a odparowanie i wysychanie długie. Im mniej produktu dawałem tym lepiej produkt się aplikował.
Docieranie na tym lakierze (spray) 3/6 - tutaj zaczynały się schody. Używałem dwóch mikrofibr Zvizzer na dwie ręce i z tego powodu, że lakier mocno tępy zaczęły z nich wychodzić mikrowłoski. Przerzuciłem się na K2 Moli i było już lepiej. Docieramy "lewitującą" ręką - czyli minimalny docisk. Mikrofibra ma jakby łapać powietrze. Im więcej dociskamy silną ręką docieranie jest długie i robi hologramy. Także dotarcie ale karate kid ale minimalnym dociskiem jakby samym ciężarem MF i w tedy szło super na tym lakierze.
Śliskość (spray) 2/6 - wręcz szorstko.
Dziś sprawdzałem połysk i średnia z całego lakieru to 95GU.
  • Lubię to 8
Szacunek za rzetelnie przeprowadzane testy. Robisz bardzo dobrą robotę.
Wyryte w skale z S20 FE 5G
Tak jak mnie docieranie nie urzeka - to dziś wyjechałem z garażu i efekt końcowy bardzo mi się podoba 🙂
