Opel Insignia 2009 - wieloetapowa korekta + UNC-R
Pogodny, widać widać :)
Slovak, Tak, dziękuję, piłem raczej do tego stwierdzenia: "zrobiłem 4 długie sprintery i dalej mam 10ml" :D
Nakładanie na grubo nie ma sensu, tym bardziej, że i tak pierwszą fibrą rozprowadza się jeszcze powłokę, a następną już dociera.
Zauważyłem, że dużo też zależy od lakieru, ale do naszej koleżanki Justyny duuuuużo mi brakuje - potrafi opędzić duże auto kilkoma ml powłoki :P
Tak tak słyszałem to już.
Zupełnie nie zgadza się z:
Every time when you move the cloth over the applied UNC-R you form a tiny layer that flashes off pretty much immediately, then you go over it again and there's another tiny layer above the previous, then another one, and then another one, till the point when the panel doesn't feel "draggy" any more and becomes super slick. At this point the layering is finished and you have to take extra care and inspect the panel fully to see if any streaks are left behind. Removing any streaks or haze at this stage is very easy, as the excess product is not sticky any more - nothing like when you started removing it.
This is because UNC-R "below the streaks" is cured enough already not to bond with anything above it, take a fresh cloth and remove everything that's left on the surface and done!
One should also find that the finish you get with UNC-R is so super clear (assuming the application went fine) that it's difficult to compare to anything else. And it's fully cured shortly afterwards - for best results leave indoors overnight and you are ready to go!
Because of these properties it is perfectly fine to use UNC-R on it's own - you will have multi layers of it applied. How many layers you will get will depend on how much product you apply on the panel to start with. UNC-R is different to UNC v2, for example - the more v2 you apply the quicker it flashes off, the more UNC-R you apply on a panel, the slower it will flash off, and you will have to wipe more times to get to a clear finish - more wipes - more layers!
This is very important for professionals who have to earn money by doing this! A single product application is much quicker than double or triple, product application, making UNC-R the perfect choice for busy professionals!
