Moderator Domel Opublikowano 23 Listopada 2012 Moderator Zgłoś Opublikowano 23 Listopada 2012 NanoSkin Autoscrub opis producenta: Cytat DescriptionNANOSKIN Autoscrub 6 inch Pad Kit with Glide - Better and Faster than Clay Wow is all I can say about this new tool and new technology. I believe this will change the way most pro detailers and DIYers will prep their cars. This is truly a time saver and will pay for itself after a couple detail jobs. We have spent in some cases 1-2 hours claying and prepping a midsize sedan (in rough shape) we recently tested the AutoScrub on an Audi S8 and we were finished in about 15 minutes! You really won't believe this until you try it yourself. The AutoScrub will make you leave your clay bar behind. NANOSKIN AutoScrub works fast and achieves professional results with the new advanced rubber polymer technology, which replaces the use of clay bars. A dual action orbital polisher is required. AutoScrub will safely and easily removes paint over spray, water spots, tree sap, rail dust and other bonded surface contaminants from the surface of automotive paint, glass, moldings and plastic. AutoScrub works great with your favorite detail spray or clay lubricant. Unlike the clay bar, the AutoScrub can be cleaned by simply rinsing off the accumulated contaminates with water. If you drop the AutoScrub on the ground, no worries, just rinse the sponge pad clean and you're ready to keep using it. AutoScrub allows for sturdy and controlled handling, unlike clay bars where constant reshaping is required. Features - Lasts up to 4 times longer than clay bars - Glides on & off easily for a slick finish - If inadvertently dropped on shop floor, simply rinse clean - Up to 50-60 uses before you need to replace it NanoSkin Glide AutoScrub System Lubricant Size: 16 oz Instant Detail Spray Lubricant Concentrate Product Description As a component of the AUTOSCRUB System, NANOSKIN GLIDE lubricates the paint so well while gliding the AUTOSCRUB back and forth. GLIDE removes minor contaminants, dust, fingerprints, bugs, and more, restoring the brilliance of a showroom finish. It can also be used on glass, chrome, and plastic. The spray dries crystal clear on any surface and enhances reflections on shiny materials, like chrome wheels and trim. It’s so easy and you can detail a full size car in less than 10 minutes. Features • A component of AUTOSCRUB • Water-based, silicone free formula • Restores the brilliance of showroom finish • Also be used on glass, chrome and plastic Directions for use with AUTOSCRUB 1. Thoroughly wash vehicle free of dust, sand, and dirt. 2. Dilute GLIDE to desired strength. 3. Mist sufficient GLIDE onto the surface evenly. 4. Polish the surface with dual action orbital polisher using light pressure (Low Speed). 5. Wipe off residue and apply wax or glaze. NOTE: Sufficient lubrication is crucial to the AUTOSCRUB application. Plain water is NOT an adequate lubricant. DO NOT use with rotary polisher. Important tips: - Make sure you break the pad in first on the windshield or glass. What we like to do is on the first use or in general start with the glass first then move on to the paint. - Sufficient lubrication is crucial to the AUTOSCRUB application. - DO NOT use water - DO NOT use with rotary polisher. Kit includes - 1 - 6 inch AutoScrub - 1 - 16 oz Glide AutoScrub Lubricant Concentrate - 1 - Kwazar Mercury Pro with Viton Seal - 1 - Uber Classic Microfiber Towel 16x16 Czy macie juz moze ten produkt ? Czy ktos to juz testowal w Polsce ? https://detailersdomain.com/NanoSkin-Au ... p_706.html Ponoć hit, który zdetronizuje glinkę Youtube: http://www.youtube.com/results?search_q ... opensearch pzdr.
bili20@o2.pl Opublikowano 24 Listopada 2012 Zgłoś Opublikowano 24 Listopada 2012 Nie mam tego produktu, jednak jestem przekonany, że niezdetronizuje glinki z jednego powodu - to jest mniej dokładne. Może i dobrze usuwa plamki i kropki z żywicy, jednak pad jest duży, więc nie wszędzie dociera, a ponadto nie mamy lakieru pod palcami, żeby sprawdzić, czy powierzchnia jest już wystarczająco czysta... Jednak czekam na opinię kogoś, kto miał kontakt z produktem
Moderator Domel Opublikowano 24 Listopada 2012 Autor Moderator Zgłoś Opublikowano 24 Listopada 2012 Rozmawiałem o tym produkcie wczoraj z Mackiem (mrCleaner). Bedzie go miec do testow za jakis czas to dowiemy sie jak dziala
poorboy Opublikowano 25 Listopada 2012 Zgłoś Opublikowano 25 Listopada 2012 Produkty tego typu dają radę Ważna jest twardość, bo miałem w rękach taki który matowil lakier. Teraz testuje ,jak to nazywam ręczny pad glinkowy I jest super, zbiera na poziomie blit hambera soft, prostu w użyciu nie trzeba zagniatac , mega zaleta, jeżeli spadnie na ziemię, myjesz woda i pracujesz dalej. Myślę że wkrótce będę miał coś na testy
saddam Opublikowano 26 Listopada 2012 Zgłoś Opublikowano 26 Listopada 2012 Ja bym chętnie wypróbował ale coś takiego do użytku ręcznego: Źródło: http://www.innovativedetailingsolutions.com/
deska80 Opublikowano 26 Listopada 2012 Zgłoś Opublikowano 26 Listopada 2012 http://www.brilliatech.com/sdp/492208/4 ... 27683.html
Moderator Domel Opublikowano 15 Września 2013 Autor Moderator Zgłoś Opublikowano 15 Września 2013 Nowy filmik
mpadlewski Opublikowano 15 Września 2013 Zgłoś Opublikowano 15 Września 2013 Fajnie to wygląda na filmie - ciekawe kiedy się pojawi w PL i ile będzie kosztować
spons Opublikowano 15 Września 2013 Zgłoś Opublikowano 15 Września 2013 mpadlewski napisał(a): Fajnie to wygląda na filmie - ciekawe kiedy się pojawi w PL i ile będzie kosztować Z tego co kojarze to LARE od dawna ma już w ofercie swój patent w takim wykonaniu
saddam Opublikowano 15 Września 2013 Zgłoś Opublikowano 15 Września 2013 Zgadza się: LARE magic CLAY PAD.
